Your Verge3D Network directory is empty.
Home Forums General Questions Your Verge3D Network directory is empty.
  • #43546
    gregor1
    My Network Directory appears to be empty, but I have numerous projects uploaded. The last time I looked at it I had so many it couldn’t display them all. This is an issue I brought up and it was being looked into. I checked it today to see if it had been fixed but now it appears empty. The projects I have uploaded still load through their URLs so they must still be there.
    I renewed my license and entered my new key on approx 7-16-21.
    #43561
    Your uploads are associated with the license key. Once renewed, you might re-upload your projects with the new key. This however will change the URLs.
    #43576
    gregor1
    Does that mean my network directory will clear out every year when I renew? The uploads will remain active, but if I edit something and re-upload it it will have a new URL?
    That would mean every project I have done for clients will have to be re-linked everywhere it is embedded or linked.
    Is this correct?
    #43596
    yes, if you want to use newest Verge3D versions with a renewed key, you have to reupload and relink the apps created with the old key.
    Other approaches:
    1. use the old Verge3D version with your old apps
    2. use your own server instead of Verge3D Network, so that you control the URLs
