.xml parameter editing after publishing
Home Forums General Questions .xml parameter editing after publishing
  • #42463
    visualizer
    Hey
    Little tricky or a very basic doubt
    Once we publish the verge 3d scene & later if somethings are modified in .xml file will that alteration work?
    Example – some youtube video link is modified after publishing or some annotation text is modified after publishing.
    is the changing of published scenes .xml parameters workable?
    is it so simple to hack the published file?
    #42589
    visualizer
    Did anyone from developer team notice my query ?
    #42635
    Do you mean the visual_logic.xml file that’s used for Puzzles or some other xml file in your app?
    #42642
    visualizer
    Hi
    Ivan
    Yes very much asking about the same visual_logic.xml file.
    #42709
    visual_logic.xml is only used in the Puzzles Editor for generating visual_logic.js, which is the file that’s actually used in the application.
    So, if you want to change the files manually you definitely need to edit the .js file. Although, I’d suggest using the Puzzles Editor locally for that and then update both .xml and .js in the published version.
    #42903
    visualizer
    Hi
    Yes Iavn,
    In some cases editing of xml worked however in some cases it didnt. So was wondering.
    As you say perhaps editing in .xml only is not sufficient & .js also needs to be handled.
    Regards
