Home › Forums › Graphics / Blender › Workflow for cutting holes in geometry and preserving normals
- This topic has 23 replies, 4 voices, and was last updated 5 years, 6 months ago by
Yuri Kovelenov.
2019-08-30 at 5:34 pm #18291
Mikhail Luzyanin
StaffSeems like your post is lost. Yes it’s almost the same, I prefer my because I can keep 4 side poligons as much as possible for better shading.
2019-08-31 at 8:25 am #18303D3Pixel
CustomerI prefer my because I can keep 4 side poligons as much as possible for better shading.
Using the Triangulate modifier by just adding it preserves the entire model, it keeps every 4 sided polygon in the viewport and in edit mode so hard surface modelling can continue, it also preserves normals whereas Triangulating in edit mode that you suggest actually triangulates the mesh there and then and destroys custom normals.
This modifier automatically gets “applied” when you export so there is no need to apply it yourself. The additional bonus is that by just having it on a mesh shows you what the model would look like (without applying it) in verge.The rule here is never apply it as that WILL screw up the mesh. Because the Verge3D exporter sees the mesh as triangulated (because it applies modifiers on export) it must skip that process. The Blender triangulation modifier does a better job as it preserves the normals whereas the Verge3D exporter does not.
Hard to explain? sorry.
Please try it to see what I mean.
3D Animation and Web3D services - www.d3pixel.co.uk
2019-08-31 at 10:11 am #18305D3Pixel
CustomerI made a video showing the entire workflow and how to preserve normals without triangulating the mesh in edit mode.
2019-08-31 at 6:55 pm #18318Mikhail Luzyanin
StaffHah, seems that they improve triangulate modifyer since last time I used it.
Usualy it broke normals and triangulate all mesh.
2019-08-31 at 7:11 pm #18321D3Pixel
CustomerYeah, I noticed you can still see the triangulation if you switch to wireframe mode but it does not create actual edges like edit-mode does making it very useful.
2019-09-02 at 5:47 am #18352Mikhail Luzyanin
StaffYeah, I noticed you can still see the triangulation if you switch to wireframe mode but it does not create actual edges like edit-mode does making it very useful.
2019-09-13 at 1:13 pm #18688Ivan Lyubovnikov
StaffHi d3pixel, we fixed this issue, now the exporter should preserve custom normals. This fix will be available in the upcoming verge3d release.
2019-09-14 at 2:34 pm #18721D3Pixel
CustomerHi Ivan, that is great news! will test it out. Thanks.
2019-10-01 at 1:43 pm #19653Yuri Kovelenov
Staff -
