Home › Forums › General Questions › WordPress Add-On Upload Error
- This topic has 25 replies, 7 voices, and was last updated 1 year, 1 month ago by
darstudio.
2020-01-01 at 5:43 pm #22498
podis
ParticipantError:
“Error occurred during upload: broken connection or maximum file size exceeded.
Please check your connection or server upload size limits.”Verge3D Add-on Version: 2.16.1
Wordpress Version: 5.3.2
Hosting Service: BlueHost
Uploading Folder: “jewelry_configurator” ~ 266M
Edited php.ini in Web_Root to:
upload_max_filesize = 720M
post_max_size = 720MI was able to upload the folder: ‘cube’ ~ 4M
I’m not sure what else I can do.. Any help would be appreciated.
Thanks!2020-01-02 at 5:06 am #22503Yuri Kovelenov
StaffHi,
Relaxing WordPress upload limits might help:
https://www.soft8soft.com/docs/manual/en/introduction/Wordpress-Plugin.html#Installation
2020-01-02 at 9:42 am #22508Anonymous
Inactiveyou could take a look at “max_file_uploads”, “memory_limit” “max_execution_time” value
greeting
A2020-01-02 at 12:49 pm #22509podis
ParticipantI have edited the php.ini file in my Websites Root Domain along with editing the one in the wp-admin folder.
I also installed a Plug-In for WordPress which helps with PHP files to see what the current settings are. (Custom PHP Settings, Version: 1.2.6)
max_file_uploads = 200
max_input_vars = 3000
max_execution_time = 180
memory_limit = 512M
error_reporting = 32759
post_max_size = 720MI also just noticed after deleting the Verge3D plug-in and reinstalling it that it has not been tested on this version of WordPress..
2020-01-02 at 1:50 pm #22510podis
ParticipantWhich might also be why my ShortCode for the app isn’t working for the Cube either.
Wonder why there aren’t many tutorials on all of this..
Plenty for publishing to Verge3D’s site, but none for uploading straight to a web server or an actual step-by-step tutorial for using the WordPress Plug-In..2020-01-02 at 2:10 pm #22512Anonymous
InactiveYou could try with value 300 by max_execution_time. Let me know.
2020-01-02 at 2:21 pm #22513Anonymous
InactiveDont worry about wordpress version. It is simple plugin and it will work for you. Webserver configuration is a bitch and tutorials for it cannot be done by soft8soft, this is completely independent problem and sometimes has to be solved individually, I try to help, ok?
2020-01-02 at 2:36 pm #22514podis
ParticipantCompletely understand and I do appreciate the help!
I’ll be contacting Bluehost regarding their php.ini files, their help docs are out of date. Once I get that straight, I’ll keep this updated.
2020-01-02 at 10:31 pm #22518podis
ParticipantOkay, Contacted Bluehost and deleted all php.ini files.
Created a new one per their instructions.
It’s located in Root which I was told is used by all domains and WordPress.Here’s the updated php.ini file: (Still receiving the error)
allow_url_fopen = On
allow_url_include = Off
display_errors = Off
enable_dl = Off
file_uploads = On
max_execution_time = 300
max_input_time = 60
memory_limit = 512M
post_max_size = 512M
session.gc_maxlifetime = 1440
session.save_path = “/var/cpanel/php/sessions/ea-php70”
upload_max_filesize = 512M
zlib.output_compression = Off2020-01-03 at 3:46 am #22534Yuri Kovelenov
Staff2020-01-03 at 8:19 am #22535podis
ParticipantI am able to upload the default Cube that came with it, yes.
2020-01-03 at 10:00 am #22537Anonymous
InactiveJust for excluding: sometimes people install plugings or Theme Customisers which have other values set as in the php.ini. This generates problems too.
Also it would be interesting to check how long an ssh session kips alive.
Aha, this is cpanel.. I never used that shit, guyes :(.Try upload the project-folder via ssh or ftp to verge directory, give some number as name for the new folder created in that directory f.e 600, and build a new post with that number [verge3d id=”600″], if its go this way, we could think, that this are wordpress-self-misconfiguration…. we could..yes.. but…we have not enough informations yet
2020-01-03 at 11:00 pm #22540podis
ParticipantcPanel -> File Manager v3:
Path: /public_html/wp-content/uploads/verge3
FTP = Successful
Renamed folder to “600”Wordpress:
Deleted all pages.
Added New page.
Add Block: [/] Shortcode
Entry: [verge3d id=”600″]SUCCESS
2020-01-04 at 10:29 am #22557Anonymous
InactiveSo you are able to upload default cube via verge3d addon and via ftp, yes?
Do you have still some issues?2020-01-04 at 12:41 pm #22558podis
ParticipantNo issues, I can FTP the files in and they work.
Thanks for all the help abin!
