Woocommerce Integration
Home Forums Tutorials Woocommerce Integration
  • #31369
    andrej
    I developed a 3D table using verge3D to use in my e-commerce website.
    The customer is able to select different colors and sizes in the configurator, change it live for the table and then click order. I’m using the WordPress plugin for verge as well.
    How can I redirect the button when they click to order to avoid showing them the order form but place the product into the cart instead and use the Woocommerce payment system? I need to capture the payment for the table right away.
    Thank you for your help.
    #31380
    Hi Andrej,
    You can use the Woocommerce puzzles for that: https://www.soft8soft.com/making-3d-product-configurator-for-woocommerce/
    #31399
    andrej
    I tried using those but since I’m using the table configurator as a way to buy , I don’t have products with variations in the shop. I’m trying to achieve this; my.deejo.com
    The way you can buy it is what I’m looking for.
    Thanks
    #31423
    There was a similar question of these forums, and somebody from the community suggested that a WooCommerce plugin for custom prices may help.
    #31426
    andrej
    Thank you for your answer.
    For me, the problem is the redirect of the button when someone wants to place an order. The order form doesn’t have a payment option and I can’t add it to the cart from the configurator. The verge3d order form pops up.
    #31438
    I see. The order form feature of the Verge3D WordPress plugin is separate from the Woocommerce integration. If you need Woocommerce, then you should not use it, but rather use Woocommerce puzzles that provide communication between the configured model and the cart.
