Home › Forums › Graphics / Blender › White outline around textures
- This topic has 16 replies, 5 voices, and was last updated 1 year, 8 months ago by
kdv.
2022-10-26 at 6:19 pm #56885
Ayakos
ParticipantHello community,
I’ve searched the forums for something similar but found nothing. Basically I want the final render in verge to look like the “premultiply setting” for alpha setting inside blender, but it doesn’t seems to pick up on this setting and it looks like simple “straight” option.
How can I make verge renderer accept this change?I have a couple of pictures to illustrate what I mean. Straight setting will have a white outline around transparent textures, while premultiply will get rid of it and make it look far superior.
You must be logged in to view attached files.2022-10-27 at 12:18 am #56890xeon
CustomerCould you post your material nodes and your object blend settings along with zdepth. Blender uses Premaultiply by default and V3D seems to handle that pretty well. I think you may have something else going on but would need more info.
Tutorials - https://www.xeons3dlab.com2022-10-27 at 2:37 pm #56932Ayakos
ParticipantYeah of course, here it is.
You must be logged in to view attached files.2022-10-27 at 5:14 pm #56934xeon
CustomerWhat version of Blender are you using? I am using 3.3 and have been able to replicate the problem. I am not sure at this time if its a Blender bug or a V3D bug.
Blender by default Premultiplied was the method Blender had been using but now the default seems to be standard which does create the white lines. Premultiplied gets rid of them in Blender but I am not certain V3D is picking up on the settings change. I will reach out through the Enterprise channel and see if they can provide any insight.
Tutorials - https://www.xeons3dlab.com2022-10-27 at 5:31 pm #56935Ayakos
ParticipantThank you. I’m using version 3.1 of Blender.
2022-10-27 at 7:13 pm #56936xeon
Customerand what version of v3d?
Tutorials - https://www.xeons3dlab.com2022-10-27 at 8:53 pm #56937Ayakos
ParticipantLatest I think? 4.1.1
2022-10-28 at 6:57 am #56938xeon
CustomerFeedback from Soft8Soft – “Alpha Premultiplied is not supported in Verge3d yet. I (Alexandar) am going to assign this task a higher priority in order to deliver this feature in the upcoming stable release of 4.2.0.”
Seems we will be waiting a bit to fix this…. Since you are using Blender 3.1 you may want to drop back to V3D 3.9.1 and give that a try.
Tutorials - https://www.xeons3dlab.com2022-10-28 at 1:39 pm #56939Ayakos
ParticipantOk Thanks a lot for the support!
2022-11-29 at 5:19 pm #58637Ayakos
ParticipantHello there, sorry for bumping this necro thread, but it’s relevant to 4.2’s release, as premultiplied was supposed to be supported now, but it still doesn’t seem to work, and textures look the same as “simple” setting.
I can provide full blender file in case my node setup is bad.
Link: https://drive.google.com/file/d/1O9sQZAK8UuBTwczcV9nGv7aTI6waKvLL/view?usp=share_link
2022-11-30 at 7:09 am #58683Alexander Kovelenov
Staff2022-11-30 at 9:47 am #58699kdv
ParticipantIn the release example the texture with the premulriplied alpha channel differes from the other three ones. The other three textures do not look like the second one even if their alpha is set to Premultiplied too. They are initially different in RGB channels.
One more thing: in his textures the image in the alpha channel is thicker. Cells in RGB are white inside (but should be black). That’s why there are white outlines inside cells.
It looks as expected if the RGB image is black inside cells. Just make a proper texture.
Straight Alpha
Pre-multiplied Alpha. It works. Looks more blue.
2022-11-30 at 5:39 pm #58718Ayakos
ParticipantThanks for the insight, but can you explain precisely what it is you did with the texture files for it to work?
2022-11-30 at 5:56 pm #58719kdv
ParticipantThat’s your texture in RGB, without alpha.
That’s how it should look to work properly.
2022-11-30 at 6:05 pm #58722Ayakos
ParticipantI see, thanks a lot!
