Where is my bump ?
Home Forums Graphics / 3ds Max Where is my bump ?
  • #31137
    NaxosCG
    Hello there,
    I’m a but frustrated because within 3dsmax it looks nice and metally and bumpy, then in Verge3D it is dull and not very bumpy…
    What did i make wrong ?
    #31140
    Please show a screen shot of the material nodes in 3ds max or better share a max file with the material and textures.
    #31141
    NaxosCG
    I had to lower roughness, and raise up metalness…
    In fact, we have to test a lot as 3dsmax viewport is not hyper close to Verge3D’s render.
    We already knew that, but it is a bit more far away than espected.
    So we do have to go further…
    #31143
    If you want to get help you need to share a material, may be it’s just a bug.
    #31152
    NaxosCG
    Here it is
    #31154
    Here it is
    Ah, yes, it’s because of roughness. The roughness in max’s viewport (2020 and eralier) works different. If you set roughness of the material to 0 you will get the same result. You can use Max 2021 where roughness in the viewport has better support so it closer to the Verge3D engine.
    #31158
    NaxosCG
    Here it is
    good to know, i’ll go to max2021 when they will release 2021.2 or 2021.3… always wait for hotfix from adesk ;-)
