When material is changed, animation stops
Home Forums Programming When material is changed, animation stops
  • #9579
    liyao1
    I have a made an interactive to test the Puzzles.
    However, when I change the material of the model, the tail animation stops. I couldn’t figure out why that happens. Any idea?
    I can send the source files if needed. Thank you!
    #9580
    liyao1
    My puzzles for this part are attached.
    #9583
    liyao1
    I changed the puzzle and used changing the color of the material instead of changing the material and it works fine. (attached file) Here is the new one that is working.
    But I still would like to know why the previous one didn’t work because I would like to swap materials entirely. Thanks!
    #9587
    If you appent material to one object to another you need to keep the same structure of the object for both object’s, so if one object has Armature the second also must have the armature with a simplifier rigging and weight. You can jsut simply can add a bone to the second object and armature.
