What is the best way to apply imperfection textures to models?
Home Forums Graphics / Blender What is the best way to apply imperfection textures to models?
  • #8933
    patrickbelt
    Hello. I commonly use imperfection textures of scratches, fingerprints, dust, and water drops on the surfaces of my models when rendering with nodes (principled BSDF) in Cycles. It looks fine until I select the Sneak Peek button, and then any scaling I’ve applied to the imperfection textures appears to change back to a default value of 1.
    Is it possible to modify texture properties/values in Verge3D? If not, is there a good work around?
    Thank you
    patrick.c.belt@gmail.com
    #8935
    patrickbelt
    Nevermind. I was able to get the desired scaling effect using the UV map and mapping nodes.
    #8940
    Glad you found a solution that works for you. Feel free to attach here an example file that does not work as expected so that we can fix the issue.
