What could be an easy/fast way to create pipeline growth animation in Blender
Home Forums Graphics / Blender What could be an easy/fast way to create pipeline growth animation in Blender
  • This topic has 2 replies, 2 voices, and was last updated 1 month ago by iren.
  • #79947
    iren
    Dear Verge community,
    please advise how I can easily create animation for pipeline growth in Blender?
    I have tried the curve+circle path animation and enabled follow path ( just in case) and also baked …animation works good on Blender … but animation doesn’t show up on Verge 3d
    Appreciate any advice:)
    #79949
    Fast / Easy is all based on the skill sets of the individual. Whats easy for one person may not be easy for another so not sure how these suggested methods will rate on the fast/easy scale.
    So if you have a straight pipe with no curves/bends…then you could use scale or create a shapekey and animate the shave value.
    However if you have curved pipes… the problem can become a tad bit more difficult.
    If you pipe has no connectors…more like a bent hose….then you can just use can use a UV map with transparency to run the distance of the pipe. You then assign value to the inputs of the UV map and animate those or drive those with puzzles.
    If your pipe has connectors: elbows, T’s, crosses, valves, etc and they are separate objects then you will need a different approach combining UV maps for the complex shapes and scale or shape key or UV maps for the straight parts.
    Depending on your situation/needs you could also use a clipping plane .
    #79951
    iren
    Thank you so much Xeon! Clipping Planes worked for me this time.
    After some attempts of trying your options: I failed with all of them except Clipping Planes. My laziness won this battle :yahoo: )))) I got lost in UV map animations and key shapes tutorials …and gave up. :unsure: One day I will get back.
    Thank you so much!
