WebGLOITRenderer – error in console
Home Forums Bug Reports and Feature Requests WebGLOITRenderer – error in console
  • #64460
    stefanp
    Hi, i have noticed an error message ” v3d.WebGLOITRenderer: render target size mismatch in v3d.WebGLOITWeighted.” It comes when I set the screen resolution to anything higher than 1. obviously it is related to Order Independent Transparency, but what triggers it? The scene has quite a few objects and animations, and quite a few materials of all types as well. Any ideas where this could come from, or how to avoid it, or where to start looking? thanks in advance, sp
    #64471
    Hello!
    Unfortunately, it is unhandled case, internal bug for v3d.WebGLOITRenderer, it does not support changing pixel density on canvas, for now I recommend not changing screen resolution with OIT, I think it will be fixed soon.
    Verge3D Developer
    #64476
    stefanp
    thanks for the quick answer!
    #65509
    Hi, check out the release to see if it works OK.
    X | FB | LinkedIn
