water effect
Home Forums General Questions water effect
  • This topic has 2 replies, 3 voices, and was last updated 1 month ago by xeon.
  • #79926
    cralex75
    Hi, I would like to create the water effect like this or similar, is it possible to do it with the Gliftek plugin?
    Does anyone have any solution to suggest?
    thanks!
    https://demo.airlapp.com/nautical/index.html
    https://gliftek.com/verge_3d_plugins/user_docs.html?page=world
    #79927
    solid
    show the AI a set of files and ask the AI. Get the build structure.
    #79929
    Well your first link is based on Unity…so having to skip that example.
    The second link is Gliftek Plugin….and will for $29 you might want to buy it and see if it works for you but it states it only works for V3D: “3.8 pre3 and under.”
    If you need an ocean that will interact with the hull of your boat then you may have to create an ocean and texture it and create multiple mesh and texture options and then use shape keys to animate the ocean. Otherwise you are limited to an animated texture map.
