VRML coordinate XZY vs. Blender XYZ
Home Forums Graphics / Blender VRML coordinate XZY vs. Blender XYZ
  • #32583
    derekwang0605
    How to convert VRML coordinate XZY into Blender XYZ? So that the object can show normally in Blender?
    #32603
    are you using Blender’s stock VRML importer?
    #32619
    derekwang0605
    I am using Blender’s importx3d to import VRML model but after importing in Blender the imported object rotation_euler turns into XZY.
    #32621
    you might try the option File > Import > VRML and see if it works better. Anyway this question is better to address to the developers of the respective plugins.
    #32647
    derekwang0605
    bpy.ops.object.origin_set(type=’ORIGIN_CENTER_OF_VOLUME’, center=’BOUNDS’)
    bpy.ops.transform.rotate(value=3.14/2, orient_axis=’X’, orient_type=’GLOBAL’, orient_matrix=((1, 0.0, 0.0), (0.0, 1, 0.0), (0.0, 0.0, 1)), orient_matrix_type=’GLOBAL’, constraint_axis=(True, False, False), mirror=True, use_proportional_edit=False, proportional_edit_falloff=’SMOOTH’, proportional_size=1.0, use_proportional_connected=False, use_proportional_projected=False, snap=False, snap_target=’CLOSEST’, snap_point=(0.0, 0.0, 0.0), snap_align=False, snap_normal=(0.0, 0.0, 0.0), gpencil_strokes=False, center_override=(0.0, 0.0, 0.0), release_confirm=False, use_accurate=False)
    I tried different ways and finally those two line worked it out!
    #32651
    thanks for sharing! glad you worked it out! :good:
