Home › Forums › General Questions › VR Tutorial for Meta Quest 3 Setup
- This topic has 33 replies, 3 voices, and was last updated 8 months, 3 weeks ago by
kdv.
2024-02-11 at 5:07 pm #70398
tomtm
CustomerMst of the time I have 90 fps
What resolution per eye? EB W and EB H values in OVR Metrics Tool.
Did you make the changes?
Yes, I reworked and optimized the original demo.
Also you can test FPS in the original demo with VR mode added.
Use this link https://v3d.net/k94 (not from the Asset Store)EW B / EW H
1680 x 1760 show’s in the tool.What is the trick with the collison, that the camera goes up the stairs?
Is there a addition in the raytrace puzzles?2024-02-12 at 3:52 am #70403kdv
ParticipantDid you test this https://v3d.net/k94? What FPS it shows?
That’s too low resolution. It gives you blurry experience in VR. You should test with at least 2064 x 2208. Actually, for the best, monitor-like picture, the resolution should be 2700 x 2700 for Quest 2 and 3000 x 3000 for Quest 3.
Is there a addition in the raytrace puzzles?Read this topic to the end
2024-02-12 at 10:12 am #70422tomtm
CustomerDid you test this https://v3d.net/k94? What FPS it shows?
<iframe class=”wp-embedded-content” sandbox=”allow-scripts” security=”restricted” style=”position: absolute; clip: rect(1px, 1px, 1px, 1px);” title=”“VR Controller Navigation (Quest 2)” — Soft8Soft” src=”https://www.soft8soft.com/topic/vr-controller-navigation-quest-2/embed/#?secret=SXmV0tDZ93#?secret=oXaqu4KgOj” data-secret=”oXaqu4KgOj” width=”600″ height=”338″ frameborder=”0″ marginwidth=”0″ marginheight=”0″ scrolling=”no”></iframe>
Where could I change the resolution?
The specs for MQ 3 is 2064 x 2208 pixels per eye.2024-07-10 at 3:29 pm #75842kdv
ParticipantMst of the time I have 90 fps, biggest dip is at 79 fps.
That’s the power of optimization
If you compare with the original demo from the App Store with the VR mode added https://v3d.net/k94 (use only this link, not from the App Store), you will see a little degradation in perfomance. Just three times less FPS. Even Quest 3 is too weak for it.
Quest Games Optimizer + OVR Metrics Tool to control the result.
