Virtual Robot Learning Module
Home Forums Projects Virtual Robot Learning Module
  • #74151
    visualizer
    Hi
    This was made almost a year before.
    Idea was to create a exact virtual replica of the physical robotic ( pick & place ) module for Training & Learning.
    Some processes are a bit lengthy if at all you cancel in between it should reset ideally but at some places randomly it crashes or behaves unexpectedly. So refresh is a way out.
    Since the basic purpose was solved the project was closed successfully.
    https://www.horizonfx.net/sample/robosample/index.html
    Hope you guys like it.
    #74161
    Looks great from the pictures! The app loading however is stuck for me :scratch:
    #74174
    visualizer
    it shouldn’t . Should load in a minute or so.
    The whole set is just 33 mbs.
    let me know if fails too often… will replace the set
