Home › Forums › Graphics / Blender › Video Texture – no textures
- This topic has 6 replies, 6 voices, and was last updated 2 years, 10 months ago by
PLAN8.
2020-05-29 at 4:12 am #28146
ad0420
ParticipantHello!
I am new to Verge3D and wanted to test out the video texture. I am following the existing video texture example in the app manager, however when implementing a materials puzzle piece, I am unable to click on the dropdown as it says <no textures> what am I doing wrong? I assume it has to do with my UV mapping?…
Any help is much appreciated :)
2020-05-29 at 4:45 am #28153GLiFTeK
CustomerAs per the instructions, use an image texture with a blank image (or ideal frame from your video) then use the “replace texture in material” puzzle to put your video file in it. Then it will work.
plz share Discord link & on your signature!2020-06-03 at 11:42 am #28343Anonymous
InactiveI am having the exact same problem. My textures in blender do not seem to export to verge? I’m trying to use the replace texture puzzle but the no textures box is red with no textures showing in the drop-down box. The exported blender file has dozens of textures. Why aren’t any of them appearing
I don’t understand the previous explanation
I’m relatively new to verge3d so any help would be greatly appreciated
2020-06-04 at 6:30 am #28369Mikhail Luzyanin
StaffYou need to create an empty (dummy) texture in the material directly in blender and put any dummy texture there, for example even a texture that has only 1×1 pixel. Them using Puzzle replacetexture put your video instead of this texture. Look at the Video Texture demo inside the engine’s app folder.
2021-06-14 at 1:19 pm #42019digitalartworm
ParticipantI am also have the same problem and the explanation is confusing
Are you talking about material with an image texture or a texture created in blender?
I too have created an object with a material which is an image texture of a flag.
When I export the gltf file – the flag shows up – so far so good.
However, when i go to use the replace puzzle – the option for replace texture is red and says there is no texture..
In your blender file with a video – you have created a material called tv screen to which you have attached an image texture called “texture for video” – this is not a dummy texture since it is the actual materiel for the screen until the puzzle replaces it.
2022-05-16 at 11:42 am #52074PLAN8
CustomerI am getting this issue – it was working, then I went to reduce the original texture image size, now it shows up that there is <no texture>
2022-05-16 at 12:42 pm #52081PLAN8
CustomerI think it is something to do with the Verge3D compression settings (render properties>enable texture compression), when I deselect this, the textures become available to select again.
