vertex displacement
Home Forums General Questions vertex displacement
  • #14171
    kenhennen
    Hey there,
    I’ve found the ninja head example illustrating the displacement map in action, however, I have a feeling that was custom code shader.
    are vertex shaders created/affected based on 3dsmax setup? i.e. the displacement map in standard or physical material
    thanks!
    www.alsber.com
    #14175
    Hi, Displacement map is not supported, yet.
    #14176
    you can probably use bump or normal map instead
    #14178
    Hi, the problem with displacement maps is that they require a really hi-poly geometry, which is not feasible to load over the network. Try using bump maps instead :)
    X | FB | LinkedIn
    #14179
    kenhennen
    thank you. just to be clear, my case is about simple lowrez geometry with noise-like texture panning to simulate fluid. the object is a sphere, so normals/parallax can only take you so far.
    i didn’t mean this as a request for adaptive tesselation [=
    meanwhile, i’ll do this in code vertex shader part
    www.alsber.com
    #55731
    Johnson
    Hi Soft8Soft!
    I wanted to ask about this– is it possible to have real-time vertex displacement in Verge3D as is possible in other editors and frameworks via Blender?
    I’ve attached a gif below for reference vertex displacement via A-Frame
    Would love to know what can be done in v3d!
