verge3d setup problems
Home Forums Graphics / 3ds Max verge3d setup problems
  • #28052
    ravenz
    Hello 2 everyone!
    There is a huge problem with using verge3d in 3DS Max 2018. Even after all steps, discribed on https://www.soft8soft.com/site, the problem didn’t disappeared.
    How I can solve this problem?
    #28059
    please try to configure the plugin path manually.
    X | FB | LinkedIn
    #28081
    ravenz
    Already done. Problem didn’t solved
    #28106
    I see, please pack your entire Verge3D installation directory, upload it to some file storage (e.g google drive), and send back to us for review. We’ll try to help you with this issue.
    X | FB | LinkedIn
    #28161
    ravenz
    ravenz
    So…Are there any solutions of this problem?
    #29108
    Sorry for the late reply. I’ve checked your installation and found that there is nothing wrong with it! Most likely there is some issue with your path. Please check again your “Configure System Paths” dialog. You might need to remove all Verge3D paths and assign a path to your Verge3D installation again. Also, please send us a screenshot of that dialog. Thanks!
    X | FB | LinkedIn
