Verge3D Server
Home Forums General Questions Verge3D Server
  • #50717
    saramontagud
    hello everyone, a co-worker and I bought the license to work together. We created a server and we both entered the license, he accesses the server that I create with the corresponding IP, however every time he tries to open a max file or a folder, it opens on my computer, is it not possible that we both edit the same max?
    #50735
    A local server will run a local instance of 3ds Max, this is by design. For collaborating on the same project, you might use the upload/download feature that we introduced in v.3.9 (see ‘Verge3D Network: Licenses and Team Collaboration’).
    Can you share the last 6 tokens of your license key so that we enable the ‘customer’ status for your account(s)? Could not find it by email.
    #50739
    saramontagud
    Hi Yuri, thanks for your reply!
    what is the ‘customer’ status about?
    #50740
    it’s just a badge on the forums – for example now you got green ‘participant’
    #50742
    saramontagud
    oh okay! 800c97
    #50743
    updated!
    #50744
    saramontagud
    thanks Yuri! I still have a question regarding the server. I created a server and activated ‘upload app sources’. My co-worder enters the ip of my server and can download my files. However if he edits for example a file max, how can I see the change? When I create the server, I have all the files on my localhost and when I make a change it is saved on localhost, on Verge and on the server, however I do not have access to see its changes, He would have to upload the project from 0 every time he modifies it?
    #50750
    well, there is no need to connect via local IP – you can just use the upload/download features of Verge3D Network.
    Be sure to enable ‘Upload app sources’ in the App Manager settings if you want to share Max files and Puzzles’ save files.
    #50756
    saramontagud
    okay thank u very much!
