Verge3D Plugin: Teleport
Home Forums Plugins Verge3D Plugin: Teleport
Viewing 15 posts - 61 through 75 (of 81 total)
  • #68848
    Flashback_Imagery.blend is not needed ))) Zip you app or at least two files (visual_logic.js and visual_logic.xml)
    #68850
    ma77hew
    @kdv There are other assets there as well, including an example
    • This reply was modified 1 year, 4 months ago by ma77hew.
    #68852
    I see only two files inside the archive: Flashback_Imagery.blend (unneeded) and Zjbcool-teleport-v1.4.zip (needed). I need you logic files to see what’s wrong. Ok, I’ll reproduce your puzzles first…
    #68853
    ma77hew
    The zjbcool zip contains the plugin and the developer’s example, you can see it in action.
    #68855
    Actually, I don’t need a working example ))) There is nothing to be fixed. It’s just working :unsure:
    #68856
    Replace four files in the plugin’s folder.
    #68858
    ma77hew
    Here is my example trying to make the plugin work using the exact same puzzle setup. Tell me if this works for you.
    https://we.tl/t-rvALQZIbek
    #68860
    Download fixed files posted above.
    #68861
    ma77hew
    Hm, I followed your instructions and the scene works in the puzzles editor now, but not when I actually run the app. Seems a little glitchy, as well. Console shown below
    https://snipboard.io/r8JYw0.jpg
    #68862
    Replace four files in .../Verge3D_Blender/puzzles/plugins/Zjbcool-teleport, reload the puzzles editor, resave puzzles. I tested with the default example. Working as expected.
    #68863
    ma77hew
    Really appreciate your help @kdv. I will take a look and see. Thank you.
    #68864
    ma77hew
    Hm, I’ve replaced the files, re-added the zjbcool folder to the plugins folder, and refreshed the puzzles editor. It works in there, but when i try running the scene from the app manager I have no success. Do you have Discord?
    #68865
    It works with the fixed plugin’s files. But with one additional condition: change the camera controls in Blender from Ferst-Person to Flying and re-export the scene. This plugin works correctly only with the Flying controls. And reduce the gaze level from 3 to 1.75-2 in puzzles.
    #68866
    Or replace this file in the plugin’s folder and it will work with the First-Person controls too.
    #68868
    Fixed. Final. See no problems in your app and in the default test. Just replace the files and resave puzzles.
