verge3d plugin not installing for maya 2020.4
Home Forums Graphics / Maya verge3d plugin not installing for maya 2020.4
  • #37714
    jemg
    Hope someone can help. I have tried installing verge3d for maya 2020.4 but the plugin is not visible in the plug-in manager.
    I have followed the install instructions so wondering if install not configured for maya 2020.4 or if there are other known issues.
    Thank you
    Jem
    #37716
    Hi Jem,
    please specify what version of Verge3D you’re trying to install and what operating system you have.
    X | FB | LinkedIn
    #37721
    jemg
    Hi Alexander,
    I am using verge3d-maya-3.5.0.exe on a windows 10 machine.
    Thanks Jem
    #37763
    jemg
    hey Alexander,
    Any clues to why this might not be working?
    thanks Jem
    #37783
    thanks for sharing this info. I suggest you do the following:
    1) check (or share here) file path in the Documents/maya/2020/Maya.env script located inside your home directory.
    2) compare this path to the path to the installed Verge3D disto
    X | FB | LinkedIn
    #37792
    jemg
    hey Alexander,
    Thank you that fixed it. for you reference…
    Maya.env file as installed
    MAYA_RENDER_DESC_PATH = C:\solidangle\mtoadeploy\2020
    PATH = %PATH%;C:\solidangle\mtoadeploy\2020\bin;MAYA_PLUG_IN_PATH=C:\Users\user\verge3d_maya\maya_plugin
    Maya.env file after fix
    It seem that there was not a space between \bin; and beginning of verge file path.
    Thank you
    Jem
    #37793
    Glad you managed to fix it :good:
    X | FB | LinkedIn
