Verge3D on AEM?
Home Forums General Questions Verge3D on AEM?
  • #66319
    oonukim2
    Please let me know if it is possible to run verge3D application on Adobe AEM server.
    #66320
    Hi oonukim2,
    This looks like a normal web server to me, so it should work!
    #66329
    erocihihape
    For me it works http://essaypapers.reviews/
    • This reply was modified 1 year, 6 months ago by erocihihape.
    #66343
    oonukim2
    Here is the response I received from our technical staff:
    Here is the “heavily customized” AEM situation that our client is using:
    ・Only HTML content tags are allowed (div, image, etc.).
    – All other tags required for Verge3D will be automatically deleted.
    In other words, <script> and <link rel> tags cannot be used, and JS and CSS cannot be called.
    ・It is a mechanism that only one JS and one CSS file can be referenced from the parent page corresponding to index.html.
    It doesn’t work because of the above.
    Is there any solution, please?
    • This reply was modified 1 year, 6 months ago by oonukim2.
    #66347
    Hi oonukim2,
    In such the case you need to “pack” all HTML UI parts into the single index.html. Also combine all JS and CSS files into single .js and .css files and link them in your index.html.
    #66348
    oonukim2
    Thanks Yuri,
    But I think it is not possible to combine “v3d.js” , “visual_logic.js”, “basis_transcoder.js” and “project_name.js” files into one.
    Is it possible ?
    #66354
    You can take a look at the React and Vue.js templates in our Asset Store where visual_logic.js is imported.
    #66358
    oonukim2
    Thanks,
    I could not access to your Asset Store via App manager due to network error.
    It says,
    “Failed to receive Verge3D Asset Store metadata, possibly due to connection error.”
    Is there other way to access?
    #66375
    Perhaps you have some firewall working?
    Does this link open for you? https://cdn.soft8soft.com/demo/asset_store_meta.json
    #66377
    oonukim2
    No, it does not work.
    Your link opens the texts in json file.
