Verge3D local live server problem
Home Forums Programming Verge3D local live server problem
  • #30906
    core3d
    When i try to import modules, verge3d local server gave me this error:
    “Failed to load module script: The server responded with a non-JavaScript MIME type of “text/plain”. Strict MIME type checking is enforced for module scripts per HTML spec.”
    I get same error when i upload to Verge3D CDN.
    But when i open my app inside Visual Studio Code and run it via live server it works fine. Also it works fine on my web server too.
    So, right now i have to finish everything with my puzzles then i import modules inside VCS. If i have to edit puzzles again i need to remove all module codes to open puzzles editor because of this error.
    How can i fix that?
    #30977
    That’s strange because Verge3D code examples use modularized Verge3D and work great from both localhost and Verge3d Network. Maybe you are using some kind of firewall or proxy server?
    X | FB | LinkedIn
    #30987
    core3d
    You can check yourself, i tried with chrome, opera, firefox and also via vpn.
    no firewall and no proxy.
    https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:1e5e88da2e/applications/pointerlock/pointerlock.html
    #31004
    Looks like you’re having an issue with MIME types. What operating system you got?
