Verge3D: get screen coordinate from 3D coordinates?
Home Forums Programming Verge3D: get screen coordinate from 3D coordinates?
  • #40100
    elie520
    Hi everyone. I’m trying to retrieve the screen coordinates of a Vector3. I’ve been playing with the vector.project method but I can’t get it to work as I’d like. Here’s the best shot I had so far:
    myVec3.project(new v3d.PerspectiveCamera("__DEFAULT_CAMERA__"))
    but it doesn’t work at all.
    If you have any idea, that’d be great!
    Many thanks.
    #40114
    You should use the application’s main camera for that, it’s available from the application instance as app.camera. Also, the project method returns coordinates in range of [-1, 1]. You can convert them to screen pixels like this:
    myVec3.project(app.camera);
    var width = app.getWidth();
    var height = app.getHeight();
    var x = (0.5 + myVec3.x / 2) * width;
    var y = (0.5 - myVec3.y / 2) * height;
    #40138
    elie520
    Thanks for your answer!
    I ended up solving my problem with v3Copy.project(getObjectByName("__DEFAULT_CAMERA__")) which is essentially the same I guess, except for performance issues. So I’ll use directly the app.camera
