Home › Forums › General Questions › Verge3d for 3ds max errors when exporting
- This topic has 19 replies, 3 voices, and was last updated 4 years, 9 months ago by
Alexander Kovelenov.
2020-07-02 at 2:40 pm #29556
jamiec
CustomerHi All,
I’m Jamie, and currently working on a video tutorial about verge3d.
Every time I export a 3ds max scene to verge3d with an hdri applied to the environment, it doesn’t appear sometimes(comes out black).
Is this to do with the fact that my hdri map is over 300MB in size?
I have also tried a 35MB hdri map, and still doesn’t work sometimes.
Is this to do with windows 10 settings?Also,3ds max photometric light and shadows doesn’t work when exported to verge3d.
Finally, the matte/shadow basic parameters doesn’t work when exported to verge3d.
I have attached my render and export settings
Looking forward to hearing from you soon!
Jamie
2020-07-02 at 2:51 pm #29560Mikhail Luzyanin
StaffIs this to do with the fact that my hdri map is over 300MB in size?
Is this to do with windows 10 settings?Usually we work with HDR images that less than 1mb and never tested an HDRi more than 4-5mb. Seems the size is the problem and seems it’s can’t loaded sometime.
Verge3D has it’s own shadow system. Look at this doc.
This material not supported.
2020-07-02 at 3:43 pm #29569jamiec
CustomerHi Mikahil,
Thank you for the answers. It’s much appreciated!
In your document, you are using fspotlight. Is that a standard or photometric light?
When exported, the verge3d lighting and global illumination doesn’t look similar to the Art render in 3ds max.Do you have a similar material that works like the matte/shadow shader?
This would be very useful for the automotive industry.The more realistic a verge3d scene looks, the more users you will have.
Kind Regards
Jamie
2020-07-02 at 5:44 pm #29596Mikhail Luzyanin
StaffMaterials and lighing (and ibl too) works different in Art and verge3d because Art it’s a raytracer and verge3d is realtime render, so you can’t get the same result.
There’s no such material, but the only way to get the same effect is to bake shadows to a map and use it as trancperency mask where dark parts will be opaque and white parts will be trancparent.Co-founder and lead graphics specialist at Soft8Soft.
2020-07-02 at 6:08 pm #29597jamiec
CustomerThe cutout toggle from physical material doesn’t work for transparency.
Do you use the transparency weight toggle instead?I don’t mind baking shadows, but don’t think many users will want to do that.
Can you make the matte/shadow shader compatible with verge3d?
Also, the hdri (ibl) only works for reflections. Not lighting.
Can you do something about it?Finally,I have tried the attached 1.4 MB hdri file. Still coming out black.
Do you know why this is happening?Regards
Jamie
2020-07-03 at 5:53 am #29599Mikhail Luzyanin
StaffThe cutout toggle from physical material doesn’t work for transparency.
Do you use the transparency weight toggle instead?Have you set a Blend type in the Verge3D settings on the material?
Can you make the matte/shadow shader compatible with verge3d?I’ll ask our programmists.
Can you do something about it?It’s works, but as I said it works different not like it works in raytracing. If you disable all reflection on materials and delete all point light sources you will se that objects still lighted. Better to compare it how it looks in the viewport of the 3ds Max than in Art render.
2020-07-03 at 7:38 am #29601Alexander Kovelenov
Staff2020-07-03 at 10:43 am #29614jamiec
CustomerOK.Thank you.
It’s much appreciated :)
Jamie2020-07-03 at 11:31 am #29616Mikhail Luzyanin
StaffIt’s also better to use one small environment.hdri only for lighting and reflection and onother one to cover background so the user will see only this image (usually jpg) as a background like it done in scooter demo. And better bake all shadows for better performand, shadows is very slow especially if you have a lot of mesh on the scene and dinamics. Look at this article and this video for more detail.
2020-07-03 at 3:37 pm #29629jamiec
CustomerHi Mikhail,
3ds max is not compatible with Art render to bake shadows (it blocks it and generates file errors).
Have you tried it before?
Your puzzles system is amazing for artists who don’t know how to code.
However, the global illumination, lighting and shaders compatibility with verge3d could be improved for artists.Most artists will be put off by having to bake, and do other tricks to get the visuals to look half decent.
Can you create a system that automatically bakes shadows, GI and lighting realistically…like unrealengine?
As mentioned earlier, your puzzles system is a thousand times better than the blue print method of unreal engine.
However, your shaders, shadows, GI and lighting could be made easier to export realistically for artists.Regards
Jamie
2020-07-06 at 6:31 am #29696Mikhail Luzyanin
Staff3ds max is not compatible with Art render to bake shadows (it blocks it and generates file errors).
In 2021 now possible to use Arnold render to bake all maps or you can use any other render engine to bake shadows. You can even use Blender or Substance Painter (a I usualy do) to bake AO and shadows map and use then in Art render then to prepear all materials for Verge.
Seems we far away from that way.
I agree, but not all of us, so the only way for now to get a good result is to bake all you can bake.
2020-07-06 at 9:17 am #29706Alexander Kovelenov
Staff2020-07-06 at 12:16 pm #29723jamiec
CustomerThat’s fantastic indeed. :) Should add this to the current tutorial?
Kind Regards
Jamie
2020-07-06 at 1:40 pm #29729Alexander Kovelenov
Staff2020-07-08 at 11:06 am #29817Alexander Kovelenov
StaffCheck it out! Feedback welcome
