verge3d export
Home Forums Graphics / Blender verge3d export
  • #14953
    lamthanhle
    Hello everybody,
    I dont know why,
    In the blender, I set up the material but when I export it, there is no material.
    Pls help me,
    Thanks,
    I use blender 2.8 beta on date: 20-05-2019 and verge3d 2.12.3.
    #14959
    Hi, can you share a blend-file to reproduce this issue? We’ve fixed a similar bug a while ago, but maybe it’s a particular object/mesh/material setup which still doesn’t work.
    #14963
    lamthanhle
    Hi Yuri,
    Thanks for your quick reply.
    After trying for a while, now open up and then the blender turns itself off.
    :wacko: :wacko: :wacko: :wacko:
    #14969
    Same for me, when I click on the 3d viewport, Blender 2.8 is still unstable. :-(
    By the way, you can try to fix it by resaving the file immediately after Blender opens it. I saved it under a different name (just in case), then restarted Blender, opened the resaved file and it worked for me – no more crashes.
    Export works fine for me, except some missing external textures, but materials are exported properly. You can also try the newest Blender build and verge3d 2.12.4 and see if it works for you.
    #14974
    lamthanhle
    Thanks Ivan, I will try it. :good:
