Home › Forums › Official Announcements › Verge3D 4.6 pre1 available!
- This topic has 36 replies, 10 voices, and was last updated 1 year, 1 month ago by
Yuri Kovelenov.
2024-02-14 at 5:52 pm #70646
visualizer
CustomerSo, what’s the problem to run the AR demo and see if it’s working?
Yes sure! I will check. I was busy with some another IAR project finishing.
will update2024-02-18 at 12:45 pm #70768visualizer
CustomerChecked the AR example, the blue colored button appears too low at bottom & feels as if out of screen handling area for user. the position seems inappropriate.
2024-02-18 at 12:59 pm #70769tomtm
Thanks for checking! It’s exactly the same here, it’s like the position is somewhere odd.
I hope there will be a fix soon, would love to check out the AR with verge3d and Meta Quest 3I already are excited with VR and the headset!
2024-02-18 at 1:06 pm #70770kdv
Participantthe blue colored button appears too low at bottom
It’s just a prompt banner. It’s position is not important. Does it disappear after you move your head looking at the floor surface?
2024-02-18 at 1:09 pm #70773tomtm
Customerthe blue colored button appears too low at bottom
Yes it dissapears but the character isn’t visible.
Maybe it’s a difference between M2 and M3. Other AR websites are working also the
provided samples in the Meta Store working like a charm.2024-02-18 at 1:12 pm #70775kdv
ParticipantYes it dissapears but the character isn’t visible.
The character will be visible only after clicking on the round cursor. Do you see that round cursor tracking the floor surface?
2024-02-18 at 1:17 pm #70777tomtm
CustomerYes it dissapears but the character isn’t visible.
Funny, now I see the cursor and can click and there is the character.
Did they change something? Or maybe it’s after a Meta Software upgrade.
Now it seems to work.I really didn’t last week. There was all odd in the headset.
Thanks !!!
2024-02-18 at 1:20 pm #70778tomtm
Thanks !!!
But the blue move around button is very close to the eyes.
Is there more interaction than just place? After placing I can’t move the character around.2024-02-18 at 2:03 pm #70779kdv
ParticipantDid they change something?
Absolutely nothing. You just didn’t know how it works and didn’t notice the cursor (even on my video example). It’s poorly visible in VR. Some corrections needed.
You can adjust its position in .blend file.
2024-02-18 at 2:39 pm #70780kdv
ParticipantCheck this https://v3d.net/9e4
Now it’s hard to miss the cursor ))) It’s green.Puzzles and JS coding. Fast and expensive.
2024-02-18 at 3:41 pm #70782tomtm
CustomerCheck this https://v3d.net/9e4
Now it’s hard to miss the cursor ))) It’s green.True, thanks!
The tracker is good to see, and the group of farmers aswell.Is it also jittering in your headset? Even the single farmer sample jitters if I walk around.
Things in VR are better tracked or look better tracked.
But maybe that’s the nature of AR vs VR… I’m a complete newbie to this, but I already could build a cool VR World.2024-02-18 at 3:46 pm #70783kdv
ParticipantIs it also jittering in your headset?
No. Check FPS in AR…
2024-02-18 at 4:07 pm #70786tomtm
CustomerIs it also jittering in your headset?
If I don’t move it’s mostly at 85 fps, when I move around 77 fps.
It seems the marker is tight on the floor, the character is slightly in the floor, it looks like
floor interect with it’s hip.2024-02-18 at 6:18 pm #70791illussimo
CustomerThanks for all the new improvements.
PWA support is an important new development. It’s a game-changer.
I have a request:
I posted bug reports on this a few times.
In 3.9.1 (and previous versions) on rollover, the outline effect used to appear without problems when the camera is outside of an environment dome. Since 4.0 and up, the outline effect only appears when the camera is close to the object. I hope you can fix this outline effect issue in 4.6.
Best wishes, Simone2024-02-18 at 7:04 pm #70794kdv
Participantwhen the camera is outside of an environment dome
What do you mean? Can you show an example?
