Home › Forums › Official Announcements › Verge3D 4.1 pre1 available!
- This topic has 31 replies, 8 voices, and was last updated 2 years, 6 months ago by
visualizer.
2022-07-19 at 10:01 am #54227
marinourso
ParticipantHi everyone, I have a problem that I can’t solve. when I append a scene and parent it to an object I can’t unload the scene anymore
No anche se faccio parent none, non fa unload
You must be logged in to view attached files.2022-07-19 at 10:13 am #54229kdv
Participantdoes it help if you unparent it first?
How can he unparent an object? Parenting to <none> just changes the previous parent object to
Scene
2022-07-19 at 10:16 am #54231marinourso
Participantpuzzle help
You must be logged in to view attached files.2022-07-19 at 10:21 am #54233marinourso
How can he unparent an object? When
targetObjName
isnone
nothing happensho risolto facendo parent ad un oggetto nascosto presente nella scena caricata
You must be logged in to view attached files.2022-07-19 at 11:10 am #54237kdv
Participantwhen parenting an object to <none> it becomes a child of
Scene
…Puzzles and JS coding. Fast and expensive.
2022-07-19 at 11:12 am #54238marinourso
Participantty
2022-07-19 at 11:26 am #54239kdv
ParticipantYou just need to parent your object back to
*.gltf
then you can unload*.gltf
with this object
Or you can parent your object to any other object that belongs to *.gltf you want to unload. Or you can just useremove object
puzzle to remove this stuck in Scene object ))) The result will be the same…Puzzles and JS coding. Fast and expensive.
2022-07-19 at 11:48 am #54243marinourso
Participantgrazie infinite per l’immediata risposta e l’aiuto che mi hai dato
2022-07-20 at 6:16 am #54250kdv
ParticipantHow many shape keys does Verge3D support? Only two (except Base)? After adding the third key I don’t see the mesh with shape keys in the scene. And it looks like that all keys can be relative to Base only…
Strange things are happening )))
One object can have many shap keys, another one after the third key becomes buggy and invisible…
2022-07-27 at 11:20 pm #54445mbhladilek
CustomerInstalled 4.1pre. It fixed the Gliftek plugin problems I was having but it generated two errors. I choose to ignore the errors to complete the installation. Please see attached images.
Thank you. I appreciate the program improvements.Attachments:
You must be logged in to view attached files.2022-07-28 at 7:26 am #54452Alexander Kovelenov
StaffHow many shape keys does Verge3D support?
It should be unlimited amount in Verge3D 4.0. Can you please share the test scene so we can take a look?
Perhaps you have previous version of Verge3D and App Manager launched when you do installation. Anyway, it’s safe to ignore these errors.
2022-08-06 at 6:33 pm #54689visualizer
CustomerI in stalled the 401 pre but nothing found in the appllications folder. its is empty.
Do I have to get them manually & put in that folder?
I wanted to see the upgraded demo examples & new added one with latest version2022-08-06 at 9:50 pm #54692kdv
ParticipantDo I have to get them manually
Press the cart button in the app manager and you’ll see all apps available to run or download
2022-08-09 at 2:20 am #54712kdv
ParticipantAnnotations are not faded when outlines are enabled. Only outlined objects affect annotations visibility. Non-outlined objects are ignored.
2022-08-09 at 3:03 pm #54715Alexander Kovelenov
StaffAnnotations are not faded when outlines are enabled. Only outlined objects affect annotations visibility. Non-outlined objects are ignored.
Thanks for reporting, going to fix this issue in the upcoming Verge3D pre-release.
