Home › Forums › Official Announcements › Verge3D 2.16 pre1 available!
- This topic has 17 replies, 9 voices, and was last updated 5 years, 4 months ago by
Yuri Kovelenov.
2019-10-15 at 10:02 am #20337
Yuri Kovelenov
Staff2019-10-15 at 10:02 am #20340Yuri Kovelenov
StaffWooCommerce integration
WooCommerce integration has been implemented in the WordPress plugin and in the Puzzles. See this tutorial on how to use this feature, as well as the video below:
E-commerce-related puzzles were moved into a separate subcategory of the Misc category, which in turn was moved closer to the toolbox bottom.
The upload function of the WordPress plugin now works better and also notifies if there were any errors during upload.
The puzzle remove object is now available for deleting objects from the scene.
The puzzle set transform now does not modify x, y or z values if these inputs are not explicitly specified (as it was before version 2.15).
The quote symbol (“) can now be used in procedure names.
The print performance info puzzle now displays how much time it took to load the scene.
Blender-specific features
The new shadows introduced in the upcoming Blender 2.81 are now supported. The new system uses the PCF algorithm instead of ESM. Since the new shadows require a lot of samples for quality shadows, they are not that feasible for efficient real-time rendering. We therefore had to optimize this algorithm and implemented an additional setting called Blur Radius to be able to tweak the smoothness.
We significantly increased the consistency of rendering of the speculars in the engine compared to EEVEE viewport.
We fixed the bug when meshes with some modifiers such as Bevel were not properly triangulated. Another fixed bug relates to the attribute optimization feature that incorrectly worked with linked materials or node groups (as in the material library). These two bugs caused loss of tangents and crippled normal mapping.
The engine now won’t crash if the currently unsupported Displacement or Specular EEVEE nodes are present in a shader.
3ds Max-specific features
The settings “Source Axis” and “aligned to Upnode Axis” are now supported for the Look At constraint.
The Spinner demo is available in the examples (the one which was used for the WooCommerce tutorial).
2019-10-15 at 10:26 am #20344D3Pixel
CustomerNew shadows! nice. One of my bug bears. Will try that out.
Also, is there a way to get really nice x-ray materials without showing internal triangulation on some detailed models? I wanted a nice partial 90% fade-out material but all of them produce weird visuals where you can see inner triangles at certain camera angles.
Also look forwards to the normal bug fixes.
3D Animation and Web3D services - www.d3pixel.co.uk
2019-10-15 at 10:52 am #20345D3Pixel
CustomerIs there a bug in this version?
New empty Blender scene (2.81 Beta), click Sneak Peak (2.16.0pre1) and the default cube renders wrong (normals are inverted) in Verge3D.
2019-10-15 at 10:53 am #20346illussimo
CustomerGreat news! WooCommerce integration
, your very clear tutorial about implementing it and all other improvements and fixes.
2019-10-15 at 1:41 pm #20352Ivan Lyubovnikov
StaffIs there a bug in this version?
Thanks for the report! We investigated and fixed this issue. It should work in the upcoming release.
2019-10-15 at 7:34 pm #20354brian.kumanchik
CustomerAWESOME!
2019-10-16 at 5:33 am #20362Andrejus
ParticipantBetter and better
2019-10-16 at 8:44 am #20368Yuri Kovelenov
StaffI wanted a nice partial 90% fade-out material but all of them produce weird visuals
got some screenshots/files?
2019-10-16 at 8:46 am #20369Yuri Kovelenov
Staff2019-10-16 at 9:09 am #20371D3Pixel
Customergot some screenshots/files?
Will get something to you later today.
Thanks
2019-10-16 at 12:05 pm #20380elk
CustomerDon’t know much about WooCommers, but I would love to see more integrations like this. Any plans for e-lerning integrations like SCORM and/or TinCan ? Easy packaging for these standards would be real nice, but more importantly having reporting to the LMS from puzzles would be a great feature.
2019-10-16 at 1:15 pm #20381Yuri Kovelenov
Staffe-lerning integrations like SCORM and/or TinCan ?
Yep, we have this in our plans!
2019-10-16 at 1:35 pm #20383D3Pixel
CustomerThanks for the report! We investigated and fixed this issue. It should work in the upcoming release.
Any ETA on a patch or the upcoming release?
2019-10-16 at 3:05 pm #20384Yuri Kovelenov
Staffny ETA on a patch or the upcoming release?
the next preview build can be expected sometime next week :)
