Hi!
I had Verge 3D installed at some point and now I’m trying to render via cloud rendering some scenes in 3Ds Max, with Vray. I’m using Vray’s cloud rendering.
Sometimes when I render on cloud, the Vray IES lights don’t work and the renderings turn out black.
I’ve had several sessions with the Vray support and found that the Verge plugin was causing the issue and corrupting the Vray IES lights in my scene. Also, I’ve uninstalled Verge a while back and have not used it on this scene that generates issues.
This problem happened on many scenes.
Is there a way to completely remove Verge from all files?
I already uninstalled and deleted all verge related files, but Verge light properties still appear in 3Ds Max, even after reinstalling it.
