Home › Forums › General Questions › VERGE is Gone after turning SSL on the domain
- This topic has 16 replies, 3 voices, and was last updated 4 years ago by
randyfive.
2020-11-21 at 8:29 pm #35607
parsec
CustomerJust turned SSL for a domain and the Iframe with verge is no longer showing anything …
What can I do?
Antonio
2020-11-21 at 8:57 pm #35608parsec
CustomerGot the hosting to remove the SSL and Verge is back again… but I will
need to have it on, once the project is online in two more days :(…Let me know
Thanks in advance.2020-11-21 at 11:12 pm #35610parsec
CustomerSo the operator helping at Hostinger told me they are using a certificate called “Lets Encrypt SSL” and told me they could sell me another called ¨comodo¨ but was not sure what the problem was and if using comodo would solve the issue…
While on SSL tested on OPERA browser and it showed ¨Some content was blocked¨ I removed the block and verge appears but then a warning is shown on the lock, there is a panel on the Hostiger site to add custom SSL in case there is something you know I can add..
Pls let me know
Thanks in advance.Antonio.
2020-11-22 at 5:02 am #35613Yuri Kovelenov
Staff2020-11-24 at 10:36 pm #35824parsec
CustomerHi! is there an way to privately send you a link?
2020-11-25 at 3:00 am #35829Yuri Kovelenov
Staff2020-11-26 at 3:48 am #35887parsec
Customersent..
2020-11-26 at 5:30 am #35900Yuri Kovelenov
Staff2020-11-26 at 6:44 am #35909parsec
CustomerSent throughout the contact form..
pls let me know , thanks in advance ..
Also ,, this is the same scene I’m having issues with textures turning black.
Antonio.
2020-11-26 at 8:59 am #35937Yuri Kovelenov
StaffSorry still no link in that message. Try using our email rather than the contact form.
Could you create a separate topic on these forums? Please post any relevant info. It would be great if you isolate the issue in a smaller project that you can share on the forums (email support is an Enterprise option).
2020-11-26 at 1:47 pm #35984parsec
Customersome how your form is filtering links
will post a link today at the end of the event.
2020-12-01 at 7:43 am #36122parsec
CustomerInstalled the other SSL certificate ,, this is one is Comodo positive SSL
Still the same problem. nothing shows up on any browser.
IF I use opera browser it lets me unblock content, and there it is the scene
is there again..What do I need to do ? any clues?
2020-12-01 at 8:27 am #36128parsec
CustomerOk this is weird if I use the direct link to the index it works…
http://xxxxxxxxx/wp-content/uploads/verge3d/1512/Index.html
Still the one on the main -congregar.mx- page using the short code is not..
Any clues?
AD.
2020-12-01 at 8:57 am #36135parsec
CustomerOk found it !!
Googled “shortcode blocked by ssl”
Solution was
in WP Settings>General
WordPress Address and Site Adress must be HTTPS… they were not..
made the change it now works.AD
2020-12-01 at 9:07 am #36136parsec
CustomerAnd just as expected ,, reactivated the free SSL on the main site , and ..
it also works, doing the same modification on settings.. -
