Variable In One Tab Cannot be accessed from another tab
Home Forums Puzzles Variable In One Tab Cannot be accessed from another tab
  • #47288
    grimmy
    IN the manual it say that
    ‘All tabs share the same namespace, so you can define procedures or variables in one tab and use them in another.’
    However, I have a variable (create empty list ) in my init tab but then in another tab when I try to insert objects into the list I get the error:
    VM7592:1074 Uncaught TypeError: Cannot read properties of undefined (reading ‘push’)
    ..as if the list cant be accessed from a different tab. Is this correct behaviour?
    #47315
    I think the init tab is special – it does not share the namespace with the rest of the tabs. You might initialize your variable in the main tab instead.
