V3DClipping and AO problem ????
Home Forums Graphics / 3ds Max V3DClipping and AO problem ????
  • #56214
    sirhc
    Hi Vergers :bye:
    I’m using V3DClippingplanes in my scene in combination with AO.
    It’s causing weird problems[See attachments]
    Is there a way to make this work or should I ditch de ‘AO’ altogether??
    Anybody know a way around this problem???(except AO baking of course)
    Project File:
    https://v3d.net/ba8
    Many Thnx!!
    Chris
    Technical Artwork Specialist@TBL.nl
    #56228
    Could you please try updating for v.4.1?
    #56229
    sirhc
    Sadly I cant due to project compatibility,…
    Is this fixed in 4.1?
    #56231
    Partially. This issue is present even in 4.2.0pre1 ))) looks like gtaoGenerator treats transparent parts of clipped objects like opaque ones. But non-clipped parts are not semi-transparent any more )))
    https://v3d.net/bau
    #56244
    sirhc
    Hi kdv77kdv,
    thanks for looking into my files(much appreciated), good to know:
    even if I would update the problem wouldn’t be solved.
    As you said partially doesn’t quite fix it,…
    Even if it fixes the non-clipped objects it still isn’t usable,…
    Guess I should
    A: ditch the clipping planes or
    B: the AO (which I like very much)…
    To Bad :-( ,….maybe/hopefully this issue can be fixed in upcoming updates?? :unsure:
    #56381
    This “ghost” occlusion is visible only if MeshNodeMaterial is behind it. It’s not visible over the background or MeshStandardMaterial.
    #56400
    Changing the blend mode from Opaque to Alpha Clip or Alpha Hashed can remove the problem in 4.2.0
    https://v3d.net/bg2
