v3d.js:1 v3d.Sprite: “Raycaster.camera” needs to be set in order to raycast against sprites.
Home Forums Programming v3d.js:1 v3d.Sprite: “Raycaster.camera” needs to be set in order to raycast against sprites.
  • #77580
    derekwang0605
    After adding line, I get below error message:
    [Violation]’requestAnimationFrame’ handler took 56ms
    Uncaught TypeError: Cannot read properties of null (reading ‘matrixWorld’)
    at rc.raycast (v3d.js:1:772400)
    at Cl (v3d.js:1:702481)
    at Cl (v3d.js:1:702554)
    at yl.intersectObject (v3d.js:1:702108)
    at YC.update (v3d.js:1:1425786)
    at ke (v3d.js:1:753789)
    at ke (v3d.js:1:754889)
    at zl.render (v3d.js:1:760423)
    raycast @ v3d.js:1
    Cl @ v3d.js:1
    function createDimensionLine(startPoint, endPoint, color = 0x000000) {
    const material = new v3d.LineBasicMaterial({ color });
    const points = [];
    points.push(new v3d.Vector3(startPoint.x, startPoint.y, startPoint.z));
    points.push(new v3d.Vector3(endPoint.x, endPoint.y, endPoint.z));
    const geometry = new v3d.BufferGeometry().setFromPoints(points);
    const line = new v3d.Line(geometry, material);
    line.name = “line001”;
    return line;
    const start = new v3d.Vector3(20, 20, 20);
    const end = new v3d.Vector3(10, 0, 0);
    const dimensionLine = createDimensionLine(start, end);
    scene.add(dimensionLine);
    • This topic was modified 6 months, 3 weeks ago by derekwang0605.
    #77602
    Hi derekwang0605,
    Thank you for posting this error. We’ll take a look.
    #77781
    The crash will be fixed in the upcoming Verge3D preview, however the Sprite objects require setting Raycaster.camera which might not be done for all raycasters used by puzzles.
    If you absolutely need this feature (sprites + raycasting), create custom-made raycasters with JavaScript.
    X | FB | LinkedIn
    #78237
    Fixed!
    X | FB | LinkedIn
