UV's prevent export !Solved!
Home Forums Bug Reports and Feature Requests UV's prevent export !Solved!
  • #15490
    ptcreative
    using Blender 2.8 25/05 Verge3D Version 2.12.5
    issue – none of my exiting models are able to be exported as Verge3D .gltf or to Sneak Peak unless I delete UV’s.Screenshot of the error attached and .blend
    I’ve tried exporting directly as well as appending then exporting. thanks
    EDIT: Turns out using it works fine with the latest build of Blender
    #15493
    ptcreative
    upon testing another object, UV’s don’t cause the error but now auto smooth normals cause the same error.
    #15496
    This issue should be fixed in the latest Blender 2.80 build. Please update Blender and see if it works for you.
