Using template and affecting performance
Home Forums General Questions Using template and affecting performance
  • #39747
    Piotr
    does using template (physics or vr) affect the performance of app by itself even when puzzles dedicated to the template are not being used?
    I’ ve built an app on physics template and decided not to use physics at the end. Should I migrate all the puzzles and so on, or it doesn’t metter?
    Thanks in advance :)
    P
    #39785
    these options do increase the size of the application by including additional JavaScript modules. Still you can easily remove them by editing the header of your_app.html file.
    #39808
    Piotr
    Thank You :)
