Using javascript animations besides scene loading
Home Forums Programming Using javascript animations besides scene loading
  • #30862
    web
    I’m in the middle of disguising the scene loading of a application.
    I’m fading in/out some html text elements on page loading. CSS animations are running well, but I need to better time some animations, also with callback if animation has finished etc. Therefor I’m using javascript but the loading in the background seems to affect the animations of the html elements, making them choppy.
    At the moment I’m using anime.js as a framework to make my life easier. Does someone maybe have some experience in that regard? Or does someone of the verge team knows how to optimize the loading?
    #30917
    Unfortunately, this is how it works for a moment. :unsure: Then the scene loads, there is too much computational work: parsing JSON, preparing scene objects, loading textures, compiling shaders, etc. Maybe in the feature, some of these can be done with a web worker, but it will require a lot of refactoring.
    X | FB | LinkedIn
    #30925
    web
    Hey Alexander,
    thx for your reply.
    Could there maybe a possible workaround of loading a smaller gltf with just a camera and no geometry. And then use the append scene puzzle or some javascript to load the “real” model afterwards?
    #30940
    you might give it a try! :yes:
    #40078
    GLiFTeK
    I have a puzzle plugin that requires the use of webWorkers.
    Is this a possibility using the verge network? (For testing at least)
    Thanks! :good:
