Using HDRI as background cant get rid of distortion
Home Forums General Questions Using HDRI as background cant get rid of distortion
Viewing 12 posts - 1 through 12 (of 12 total)
  • #63768
    3dcgi
    Hello
    I’m trying to using a HDRI as background, but I can’t get rid of the distortion
    I’m using the OSL HDRI environment node, added a HDRI from polyhaven (2K) and trying to adjust the image using ground projection to get it set up
    Anyone here who has a solution for that?
    Senior CGI Artist @ 3DCGI.Studio #zerophotography
    ➤ Unreal Engine - 3ds max V-Ray
    ➤ Hyper-realistic 3D. Cars, Motorcycles, Products, Archviz Visualizations, 3D & VFX Animations
    #63769
    Try using an environment background node
    #63780
    3dcgi
    Is this inside the puzzles?
    I’m new to Verge3d and still try to figure it out
    Could you give me some additional help please?
    #63801
    Can you give more information^ what kind of distortion, screenshots, example of HDR map. Better to attach the scene.
    #63806
    3dcgi
    Hi Mikhail
    i just created a new test scene, using the same config as on the large one, who gives me the error
    I did that instead of uploading 130MB
    please download the scene here
    https://3dcgi.studio/temp/environment_test.zip
    Now I have this brown floor in there too and have no idea where it comes from – see attachment
    What am I doing wrong here?
    • This reply was modified 1 year, 10 months ago by 3dcgi.
    #63809
    You aren’t doing anything wrong but the image you are using is pixelated.
    Just keep in mind that its an equirectangular image that is being wrapped to the environment.
    To get an idea of the quality of your HRDR image open it up in an image editor and zoom in to the level you see in 3D space and you will see how the image you have started to break down.
    The image in your 3D view looks exactly like the image when scaled to match.
    Interested to know if someone at Soft8Soft has a way increasing the distance of the environmental maps to allow us to adjust their size
    • This reply was modified 1 year, 10 months ago by xeon.
    #63811
    3dcgi
    Hi Xeon
    the image is pixelated as it is only a 2k HDRI
    Didn’t want to use a 16k as it will only add to the download size
    My problems are with the distortion when I use the HDRI as a background – see screenshot
    I know that it is possible to use HDRI as a background, found a site who they used a HDRI from polyhaven
    Unfortunately, I didn’t bookmark the site and can’t find it anymore in my history
    How would I use this environment node you are talking about?
    Right now I use OSL HDRI environment node inside 3ds max, maybe that’s the wrong way?
    #63813
    3dcgi
    found the link
    https://www.dongfeng-nissan.com.cn/activity/car/qashqai
    this one is made with the HDRI from polyhaven
    and here another one
    https://www.dongfeng-nissan.com.cn/activity/car/altima
    not sure if that is also a HDRI from polyhaven
    Although it is not 100% it is much better then the results I got
    #63817
    In both cases they use 4096×2048 equirectangular map in .jpg. And they apply those textures to a big semi-sphere (with a flat base).
    Something like this
    The same approach is used in the Firstperson Camera demo
    #63830
    unfortunately the “Ground Projection” feature is not supported for HDRI Environment textures at the moment. This feature is in our TODO list though. As suggested above, you might need to create a “Dome” by using a regular textured mesh.
    X | FB | LinkedIn
    #63831
    3dcgi
    Something like this
    Thats a great info, thanks for your help.
    #63832
    3dcgi
    Thanks for clearing that up. I will use KDV’s advice until ground projection is supported
