Use Blender Python Script to Export to Verge3D GLTF?
Home Forums Programming Use Blender Python Script to Export to Verge3D GLTF?
  • #44703
    techrise47
    Hi all,
    I would like to export verge3D compatible GLTFs directly from the Blender Python scripting interface but I am afraid I just don’t know exactly the mechanics for calling the correct export functions from the Verge3D addon (it imports no problem, so I have access to all the functions, I just don’t know what function(s) to call or how to tweak the settings).
    Might there be some sample code available that shows how you could export a blender scene to GLTF as if you were just manually clicking the “export to Verge3D” option on the export menu?
    Any help would be hugely appreciated. Thanks!
    #48013
    David Bujeda
    I’ve been searching for exactly the same and found the following command in the web:
    bpy.ops.export_scene.v3d_gltf(filepath=”/path/to/file/example.gltf”)
    However, the output for me is:
    AttributeError: Calling operator “bpy.ops.export_scene.v3d_gltf” error, could not be found
    Can you give it a try and see if it works for you? It should be working but I don’t know what I’m doing wrong.
    It would be great if someone from the dev team could give us a hand here
    #48032
    It should be
    bpy.ops.v3d.export_gltf(filepath="/path/to/file/example.gltf")
    X | FB | LinkedIn
