USDZ Export from Verge3D
Home Forums General Questions USDZ Export from Verge3D
  • This topic has 4 replies, 3 voices, and was last updated 1 year ago by kdv.
  • #70100
    Philipp
    Hey,
    is it possible to have a configurator where different combinations are created in verge3d.
    So there will be a few parts and a few materials and textures which the user can configure.
    My plan is to export that exact configuration directly from the configurator as usdz.
    Any info on that? I dont want to create the preconfigured models because there are more than 500+ possible combinations. :-)
    Thanks a lot!
    Greets Phil
    #70103
    The export to USDZ gives you the option to select object. You can choose which objects you want to export by making the object: all objects, a collection, a list defined by a variable, etc.
    This gives you the freedom to export what you want or in your case what your users configure.
    #70106
    :scratch: try to export to USZD a list of meshes (using the corresponding puzzle in Verge3D) and see the result. It’s possible to export several meshes but not this way…
    #70108
    So what? That puzzle creates one mesh (removing initial meshes). And yes, this one comlex mesh can be exported to USDZ (provided its materials are glTF compatible).
    There is a non-destructive way to do the job…
