Uploading doesn’t update the Project
Home Forums General Questions Uploading doesn’t update the Project
  • #34140
    philley
    Hello,
    I have a problem with the display of my last project.
    I implemented a UI with Workflow and afterwards changed the icons pictos. (I updated the HTML folders in my application folder)
    Now when i run the .index from the Verge3D App Manager it works fine and the pictos changed.
    When I publish it to the Server however the pictos aren’t changed.
    I hope you can help me out,
    best regards,Phil
    #34149
    Hi Phil,
    There is a 15 minute timeout for refreshing on Verge3D Network. You can set it to 0 for faster interactions.
    https://www.soft8soft.com/docs/manual/en/introduction/App-Manager.html#App_Manager_Settings
    (“Verge3D Network cache age”)
    However this should only be used in development. For best performance of caching capabilities you might restore it back to 15 or more.
    #48515
    cg-physics
    ok, wow, that explains a lot.
    I have a suggestion: Please always write this to the message “Your web application has been successfully uploaded to Verge3D Network….”
    something like: “Right now your Settings are … You can change them …”
    Thank you! :bye: :rose:
