Upload texture Verge 3D network Issues
Home Forums Graphics / Maya Upload texture Verge 3D network Issues
  • #38043
    lumin8
    I’ve been reviewing my scene locally through Maya and Sneak Peek and everything is fine. Once I upload my scene to the Verge Network, some textures show and others don’t. I deleted everything one by one and noticed there are certain textures themselves that are causing the issue. If I swap them with other jpg, they work fine. They are all jpgs, same resolution and save out of Photoshop. I even converted them to PNGs and they still didn’t work. There appears to be something strange going on with some textures themselves when published. Any insights?
    #38106
    lumin8
    I solved the issue with a work around by resaving the the jpg which originally was saved from a PNG. The images are identical size and look the same but noticed a difference in the image data stored within the jpg file preventing from rendering on the network. As mentioned It works locally but not on the network. I’ll repost this a bug. You server doesn’t seem to like it.
    #38107
    lumin8
    Ok… confirmed. I removed all the metadata and the jpg image and it works on your server. As mentioned, the original image was created from a PNG file. I’m ok with this as it helps both on file size and easy to fix my scene without adjust textures. I’ll just run a script to remove all metadata from my jpg textures.
    #38115
    lumin8
    A new update. It wasn’t any of the above. It was the naming convention. My file name had a “+” in the name (“Chair_AO+Shadow.jpg”). When I originally changed the name, that was what made it work and not the removal of the Metadata. You server obviously doesn’t like the “+” symbol but works fine when reviewing locally. I’ll retest my entire scene by just changing the names.
    #38119
    windows doesn’t allow “+” in the name of a file… I wonder how could you name it so?!
