Upgrading to Verge 4.7
Home Forums General Questions Upgrading to Verge 4.7
  • #76257
    jasonod888
    Iv been using Verge 3D 4.6 with Blender3.6 for a while now.
    I have decided to move to Blender 4.2 . I have a lot of projects created with blender 3.6 ( and verge 4.6 ). Will i run into any problems when i upgrade both blender and Verge ?
    My primary concern is the Puzzles. As long as the overall structure and logic is saved and not effected, i should be able to debug everything else. better, is there is way to maintain verge 4.6 in the earlier version of blender and use Verge 4.7 in blender 4.2 ?
    Thank You
    #76260
    The main issue you should be aware of when upgrading to Blender 4.2, is that some settings are moved to their new places (see here). The Puzzles should be 100% compatible with the new version though.
    The general recommendation regarding updates is the following: you should use the most recent version for new projects and keep the old one if you are in the middle of production and going to complete your project soon.
    X | FB | LinkedIn
