Home › Forums › Programming › Updating object scale to appear consistent regardless of distance from camera
- This topic has 5 replies, 3 voices, and was last updated 1 year, 2 months ago by
masj.
2024-01-08 at 7:56 pm #69540
masj
ParticipantHello!
Linear algebra is def not my strength as a creative-type first. Hoping a kind technician in the V3D community can help me with something I’m trying to build.
The goal is to update the size of a given Object3D(s) to remain visually consistent, regardless of its distance from the app’s camera. Think I’m getting the distance between the object(s) and the camera correctly – was able to get this far:
function setObjectConsistentScale(objs) {
var [_vec1, _vec2] = [new v3d.Vector3(), new v3d.Vector3()];
objs.forEach(obj => {
var objDist = obj.getWorldPosition(_vec1).distanceTo(app.camera.getWorldPosition(_vec2));
console.log(objDist);
// obj.scale = (?, ?, ?);
}What to do next is…where I need help, especially when we start potentially factoring in camera zoom, FOV, etc.
Any guidance on the matter would be HUGELY appreciated. Thanks!
2024-01-08 at 8:45 pm #69541xeon
CustomerAny chance you can describe the use case?
Tutorials - https://www.xeons3dlab.com2024-01-08 at 9:18 pm #69542kdv
Participantfunction setObjectScale(mesh, factor) { if (app.camera.isOrthographicCamera) factor = ((app.camera.top - app.camera.bottom) / app.camera.zoom) / factor; else factor = (mesh.position.distanceTo(app.camera.position) * Math.tan(Math.PI * app.camera.fov / 360) * 2) / factor; mesh.scale.set(1, 1, 1).multiplyScalar(factor); }
2024-01-08 at 11:00 pm #69544masj
Participant@kdv, you are brilliant! Thank you once again for sharing your insights. Really appreciate your help.
Can I ask a follow up question re: the ‘factor’ arg?
I think I found a way manually to set ‘factor’ on a per-object basis via its bounding box & Math.cbrt to keep it at the same scale as inside the 3D model file itself, but was wondering if you knew of a cleaner/simpler way to do this via maths inside the function call, when an object’s bounding box will have grown/shrunk with the object’s scale (hope that make sense).
@xeon, for sure! I was envisioning something almost like fancy 3D UI annotation-like objects on the surface of model(s) in an app with lots of leeway for zooming, kind of like the feel of zooming in to a 2D map in an app, but w/ some proper 3D fanciness.2024-01-08 at 11:10 pm #69545kdv
ParticipantCan I ask a follow up question re: the ‘factor’ arg?
using this argument you can adjust the desired visual scale. Higher values make objects smaller. You may start with 5 and then adjust scales as needed.
The way to apply scaling per object:
object.onBeforeRender = function() { setObjectScale(this, 5); };
2024-01-09 at 12:46 am #69546masj
ParticipantThanks for the breakdown.
Again, you’ve been amazing, and thanks for the help! -
