Update text object on a surface
Home Forums General Questions Update text object on a surface
  • #17187
    yasse
    Hello,
    I’m working on a shirt configurator, i have a text projected on it, using a lattice.
    on blender, it’s working good, but when I try to make a sneak peak or open the project it’s not anymore on it position it’s kind of flat text and don’t fit to surface,
    is there any way to fix this without baking the text object because I will need to update it lately
    thank u for your answers.
    #17192
    You can leave text editable in the engine only in it’s pure flat mode without modifyers or you need to check Bake Text checkbox, but the text will be not changable in the engine.
    #17322
    yasse
    @Mikhail, Thank you for the answer yes I Knew about this, but my concern was more for a curved or rounded surface, like a mug, for example, something as custom printing..
    I Have in mind to make an html text input, and then apply style css(font, sizes)
    and then convert it to image, so that using javascript, and the every keyframe puzzle apply that image as a texture to that surface,.. Sounds not that clean, but hopefully it will works :)
    #17336
    Yes, this must work for you.
    #17925
    bkwok
    Hi, I wonder is it possible touse puzzles to generate 3D text?
    #17933
    If you are a Blender user, then you can use this puzzle for creating 3D text
    https://www.soft8soft.com/docs/manual/en/puzzles/Objects.html#update_text_object
    #17938
    bkwok
    Thank you, I will try it.
