Update data after scene update
Home Forums Puzzles Update data after scene update
  • #27202
    David Duperron
    Hi!
    I have a project where I want to switch between several scenes (several .gltf files) which have the same structure (same collections, object types, etc…).
    I manage to load the scenes correctly, but It seems that I cannot updates my lists of available objects correctly…
    For example at the first loading I load scene01.gltf with several objects in the Collection01. I can manipulate them correctly.
    When I switch to scene02.gltf, the scene loads correctly, it has a Collection01 inside, but I cannot access its objects… I only see objects which have the same names as in the scene01.gltf/Collection01. Any new object (not present in scene01.gltf/Collection01) is not accessible.
    First is it clear? And if so, is there a way to update the collections/groups/objects upon a new scene loading?
    Thanks!
    David
    #27203
    Hi David,
    Dropdowns are not updated when a new scene is loaded. But you could use Text puzzles with collection names rather than dropdown selectors.
    #27204
    David Duperron
    Ok, and doing so, I can force the refreshing of the objects included in a specific collection upon the scene loading completion?
    #27206
    I guess you need to unload the first scene just before loading new scene. Otherwise you’ll have 2 collections with the same name.
    #27210
    David Duperron
    Thanks for your answer! but I cannot make it work… I tried unloading the current scene and loading the new one… Just sent you an email!
    #27214
    I checked out your project you sent by email. Could you please try the following:
    place the “when hovered” puzzle after a scene is loaded, using the “when loaded do” slot of the “load scene” puzzle
