Unwanted behaviour with registerOnHover and for loop
Home Forums Puzzles Unwanted behaviour with registerOnHover and for loop
  • #40076
    elie520
    Hello,
    I’m trying to have an outline when I hover all the objects of my scene which fit a certain criteria.
    When I do it manually, with
    registerOnHover(obj1,false,function(){outline(obj1, 'ENABLE')},function(){outline(obj1,'DISABLE')});
    registerOnHover(obj2,false,function(){outline(obj2, 'ENABLE')},function(){outline(obj2,'DISABLE')});
    it works fine. But when I try to use a for loop like this:
    for (var a = 0 ; a < objs.length ; a++) {
    registerOnHover(objs[a],false,function(){outline(objs[a], 'ENABLE')},function(){outline(objs[a],'DISABLE')});
    whenever I hover one of the objects, it is always the last one of the list that gets outlined.
    If anyone could help, it’d be greatly appreciated :)
    Thanks!
    #40079
    elie520
    I could solve my problem using _pGlob.hoveredObject in the following way:
    registerOnHover(objs[a],false,function(){outline(_pGlob.hoveredObject, 'ENABLE')},function(){outline(_pGlob.hoveredObject,'DISABLE')});
