UnloadScene in Vue.js
Home Forums Programming UnloadScene in Vue.js
  • #38443
    David Duperron
    I am working on the integration of Verge3D content in a Quasar environment (based on Vue.js), and I am facing an issue.
    It seems that whenever I reload a page where I have a Verge3D scene loaded, it creates a new instance of everything, and that for example a function that is triggered when I hover an object is triggered once the first time the scene is loaded, twice the second time, 3 times the third, etc…
    Is there a way to “kill” the scene and everything attached to it (script, etc…) when the vue is destroyed, for example by adding something in the beforeDestroy section of the Vue file export_default??
    Thanks for your help!
    David
    #38450
    David Duperron
    I think I found a solution myself…
    I simply removed the listener associated to the scene by adding the following:
      beforeDestroy: function () {
        eventBus.$off();
    It seems to work fine!
    #38452
    Hi David! Glad you worked it out! :good:
