unknown property sneak peek in undefined
Home Forums Graphics / 3ds Max unknown property sneak peek in undefined
  • #26415
    lbpa
    Anyone know how to fix this error:
    “”unknown property sneak peek in undefined””
    – It also appears when any of the other commands are invoked from the Verge3D dialog drop-down in max.
    Thanks!
    #26431
    this hints that the Verge3D Max plugin is not properly installed. Please check the paths
    https://www.soft8soft.com/docs/manual/en/max/Installation.html#Configuring_Plugin_Path_Manually
    #26452
    lbpa
    looking now.
    thanks Yuri.
    – is this an indication of the problem on my home machine:
    (run from regPlugPath.bat)
    – other machine (my office) is running OK from the dropbox installation.
    #26454
    lbpa
    – running the .bat locally now.
    #26455
    lbpa
    Yuri,
    I was able to recover the parameters here:
    – I registered the v3d menu & added v3d params
    works perfectly now.
    – really appreciate your excellent support.
    #26458
    glad you worked it out! :good:
    #26460
    lbpa
    Yuri,
    I’ll say it one more time.
    Thanks for your excellent support.
