Unable to export gltf via python script
Home Forums Bug Reports and Feature Requests Unable to export gltf via python script
  • #49511
    David Bujeda
    Hello,
    I’m trying to import an stl into a scene and export it as gltf using the following command:
    bpy.ops.v3d.export_gltf(filepath=”/home/dbujeda/pruebas/simulation.gltf”)
    That’s all I need to do for this script. However, it returns the errors attached.
    I’m using Blender 2.83.9.
    #49532
    hi,
    I think this is somehow connected to LZMA compression. As a temporary workaround, you might disable it and see if it helps.
